Old 06-10-2015, 09:11 AM   #3
JFP in PA
Originally Posted by hancock1701 View Post
I think Motive only has a universal adapter for Hondas, which is the one with the chain around the reservoir to clamp it down. People on Honda forums say that adapter is very flimsy and hard to set up for air tightness.
There are two different size adaptors for the Honda/Acura line: Honda uses two size reservoirs. One reservoir is approximately 2.5" in diameter - that one uses the 1101 cap which comes with kit 0101. The other reservoir is about 3" in diameter. It uses cap 1119 which comes with kit 0119. You can use the 0119 on both size reservoirs, however the 0101 will only work on the smaller Reservoirs.
While both are "universal" style adaptors, they both work well, we use them regularly.
