Old 05-27-2015, 08:24 PM   #1
thstone
In all seriousness, I'd put in some fresh gas, oil, and a filter and see if it fires. If the engine starts, then I'd follow up quickly with an entire major service.
Then I'd drive it until I found a problem.
Then fix it.
Then fix it.
Then fix it.
You get the idea...
If you can DIY some of the work, I would recommend a stack about 20 high of those home printed $100 bills to get you through the first year. If everything has to go to a shop to be fixed, go 30 high on the stack. And that will just be to get it and keep it mostly running. Rehab will take a separate stack...
Did your F.I.L. mention that there are no cheap Porsche's?
