Thread: Clutch Bleeding
Old 05-24-2015, 08:17 AM   #2
JFP in PA
Originally Posted by clickman View Post
I bleed my clutch every time I flush the brake / clutch fluid. I pump up the Motive and do the four brakes first, starting with furthest from the master cylinder and working to closest. Then, without releasing Motive pressure, I push down the clutch pedal and hold it down with a stick. After bleeding at the slave, I release the Motive pressure and lift up the clutch pedal from the floor. Is that the correct way to do it?
Yes.......
