Old 05-19-2015, 04:42 AM   #11
Timco
I am my own mechanic....
Timco's Avatar
Originally Posted by Bruce Wayne View Post
Jeez! How many beer breaks did you have
Went in from panel behind seat. Had to buy one wobble head socket. Then low temp stat. The I did all coolant. Then UD pulley, belt, done. I'm in no rush.
Metal impeller?? When mine failed, I knew because the bearing had allowed play and THE IMPELLER WAS RUBBING THE BLOCK OPENING where the pump sits. If it was a metal impeller............ Which do you think will grind down first? The steel impeller, or the aluminum block? Aluminum in the coolant is not good.
Glad when I cut open my coolant filter and no shavings! Or fluid even??? Chicken feathers??? Oh, that was the cabin air filter.
'08 VW Touareg T-3 wife's car
