Old 05-05-2015, 06:45 PM   #1
aczyzewski
CEL P0306
Originally Posted by BFeller View Post
That is correct, they are a fixed length. It has been over a uear since I removed/reinstalled mine. I can't tell you how to get them connected - other then make sure the clips are in well, or they might fall out again.
Thanks. That helps. I am beginning to think that the alignment of the drive mechanism is off a bit and that is making it out of reach when I try to reconnect. Like was mentioned in other posts, there was a lot of tension on the pushrods when I popped then off.
aczyzewski is offline   Reply With Quote
