Old 04-30-2015, 07:37 PM   #2
dghii
The bulb is out. You will need to pull the cluster to replace.
+1. I bought a 98 Boxster years ago on the cheap ($4,800). One of the things that the owner listed is there was no odometer readout. When I went to look at the car, it was sitting as just the right angle with the sun behind the car that I could make out the faint display.
I pulled the cluster and replaced the bulb.
Also note that if you ever lose your cruise control function, it'll mostly likely be a bad bulb (really)!
dghii is online now   Reply With Quote
