Old 04-27-2015, 08:18 AM   #10
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by stateofidleness View Post
So I took her for a quick run to the ice house today to refresh my memory on the symptoms...
The noise seems to disappear (most likely just not loud enough) UNDER 20mph. Above that and I start to hear it. "Speed" of the noise does appear to change as I go faster. Noise sounds more prominent when decelerating, but I may attribute that to less noise from exhaust and engine during deceleration so it doesn't muffle the wobble noise as much. Turning does not alter or affect the noise at all.
Okay then what happens when you have the car making the noise and you put the trans in neutral letting the rpm drop to idle?
