Old 04-16-2015, 07:54 PM   #1
KRAM36
Need For Speed
KRAM36's Avatar
I would find out how long it was driven with the bad AOS. That can muck up the converters if ran that way long enough. Replacing the cats is not a cheap fix, spark plugs are though.
I'd worry about the "candidate for retrofit" as to what they meant. If they meant the IMS is at a failing stage then you better get that replaced asap. If it goes, you're looking at a engine rebuild or installing another engine.
2003 Boxster S
