Old 04-11-2015, 11:21 AM   #10
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Dgrange View Post
Hi,
Just read the full thread and again must be missing something?. No info on removing the light and a step by step of what to do? A few pics of before and after but nothing I can use to start the project.........
Quiz questions:
Answers posted in white text below the question. (Nearly invisible with my settings)
1) How long did it take PW to complete one lens?
63 minutes
2)What speed should the Dremel tool be set to?
Slow is the key. I set the Dremel to its slowest speed
3)How thick is the lens over the turn signal area?
The bulk of the lens (main portion) is 3mm thick. The turn signal area is just over 6mm thick...
4)What lubricant is suggested?
use a thin lubricant like WD-40
5)What forum makes PW sad?
the 996 ForumClick this link
6)What UK member made a follow-up post, displaying pictures of his headlights being de-ambered?
BoxPaulie
7)Are there threads and videos about how to remove the headlights on a 986?
YesClick this link
If you scored 7/7 you win Free Shipping* on parts orders from Pelican Parts!
If you failed (Less than 4 correct) DO NOT ATTEMPT THE DIY.
Thanks for playing.
