Old 04-24-2006, 04:20 PM   #1
blue2000s
Porscheectomy
Like was said above, the brake pads are cheaper to replace than the clutch, which do you want to replace?
It is good for the brakes, clutch and fuel economy to drive smoothly and slow down as much as possible by leaving the car in gear and letting it coast to slow it down. Just leave yourself room from the car in front of you and you can do alot to prolong the life of your brake pads. This also gives you reaction time to just let off the gas instead of hitting the brakes when the car in front of you hits it's brakes to make minor adjustments in speed. The smoother you are, the more your car will apperciate you.
