Old 03-23-2015, 06:56 AM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
My battery is now almost 4 years old and I regularly go for 2 to 3 weeks without starting it, all the while using the car to test and align customers headlights.
Even after that, the battery cranks fast and hard as if it was not affected at all.
You either have a bad battery or a slight parasitic drain. When your mechanic drained the battery, he really should've replaced it because they are never the same after that.
Particle, yours is a '99 and his is an '01+. The '01s have more of a drain because of the 'improved' central locking unit (CLU/Immobilizer box/'thingy that gets wet and kills the car'). Still, 2 weeks from full charge to dead sounds like time for a new battery or check on the voltage regulator.
