Old 03-22-2015, 07:12 PM   #1
KRAM36
Need For Speed
KRAM36's Avatar
Have you checked the airbag retaining frame and its bushings? I'd bet that it is the problem. Mine did the exact same thing with worn bushings.
The first time it happened, I was at work and it blared for nearly an hour before blowing the fuse. Replacing the fuse caused it to honk and immediately blow. Once the frame was fixed, it worked as it should without blowing the fuse when used. I'm not sure why...
It's very possible that a horn is bad, but the retaining frame is an easy fix and should definitely be checked before buying a horn.
Were is this bushing located? I just pull my 3 stalk full housing and all (broken turn signal stalk). Would I have the part to help him out?
2003 Boxster S
