Old 02-25-2015, 05:51 AM   #2
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by edc View Post
The standard intake pipe that fits over the 68mm TB won't fit over the 75mm TB so you will need to get creative.
Correct, however the OD of the part that goes over the TB is 80mm which is the same size as the OD of the 76mm TB. So you just have to use a 80mm ID silicone tube to connect them. I've also reenforced the thin wall of the stock pipe.
2003 Boxster S
