Old 01-29-2015, 02:38 PM   #11
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by mikefocke View Post
Why the flatbed it worry? Was there a noise or symptom that led you to believe that the car won't run for the few miles to a shop just as it has for its 60k+ miles? If there was, then by all means flatbed and don't turn it over. Critical to the success of any IMS replacement is making absolutely certain that there is no debris already floating around in the engine.
$4k is twice what I see people posting as labor costs. More common is ~$1k for a manual. More for a TIP as the whole engine/trans unit has to be removed and then replaced. Which might get you to $2k but certainly not $4k. What is his hourly labor rate?
And are you doing anything else while you are there? AOS, water pump, clutch, plugs/tubes/coil-packs, etc?
How much does the Flat6Inovation DOF Retrofit kit cost?
Here is what he stated in email correspondence.
"Depends on which route you want to take. If you want to go with the standard
single row LN engineering bearing, (assuming replacing clutch and a few other
while in there items), it usually comes out in the $3000 range with the
tiptronic due to the extra labor of the tiptronic. If you want to go with the
IMS solution which utilizes an oil fed bushing system to replace the bearing,
that runs about $4000."
