Old 01-14-2015, 12:43 PM   #19
kk2002s
kk2002s's Avatar
WOW did this thread ever go sideways.
Do you get grind/issues shifting at lower RPMs?
Where is your clutch pedal engaging (Bottom-Floor, middle, top) should be middle-ish
You can do as mentioned Fluid changes, front motor mount. This would not be a waste of time as mounts typically need replacing anyways and fluid changes (trans & clutch) are just good maintenance.
There are also (2) trans mounts. I believe they are filled with fluid so when they go bad they tend to leak
I'm not familiar with the shift cables but could that contribute any way?
Welcome
Seal Grey
