Thread: Immobilizer
Old 12-28-2014, 12:56 PM   #5
JFP in PA
I'm thinking that "Yes" means that it will trigger a fault and your SRS module will require a reset, not that your airbags will explode. I bet that your SRS module already needs to be reset.
I'm pretty sure that I have powered it up without seats, but then again, I may have had them plugged in, but not bolted.
Disclaimer: JFP is a Pro and knows this stuff. I am more of a trial-and-error guy. Don't put your face or any sharp objects in the line-of-fire just in case.
You are correct, I meant that it will force the car to code for an airbag fault.
