Old 12-16-2014, 01:17 PM   #1
Steve Tinker
Steve Tinker's Avatar
Why are you considering changing the pads and rotors just because they have done 30k?
Surly an inspection of each component is warranted before making a decision. Are the pads worn down to the sensors? Have the rotors a lip on he top circumference? If so, have you measured the thickness to see if they are still in spec?
Changing out all 4 brake rotors, pads, sensors, fluid etc. is not a cheap operation, especially if you use high quality parts....
2001 MV Agusta F4.
