Old 11-22-2014, 11:02 AM   #1
thstone
I'd like to inquire about your current suspension set up and why the need for racing slicks, but I'll just answer the question;
The typical camber plate will provide ~1 deg over stock (so you might get right around -1.9 to -2.1 deg total camber). Very few (if any) camber plates offer enough adjustability to get to -2.5 deg of camber.
Alternatively, some people modify the upper strut mount area (drill out a wider section in the sheetmetal) to get more adjustment. Personally, I do not like this method (IMHO its a bit of a hack) but some have done it successfully.
Otherwise, to get -2.5 deg or more of negative camber, you will likely have to use adjustable lower control arms.
