Old 10-22-2014, 09:51 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Are you installing your tip, or the 5 speed? Changing the transmission type will give you problems.
The car receiving the engine is a Tip and remaining a Tip. I am just putting in the engine from a same-year 5-speed.
5. Serpentine belt tensioner pulley and Idlers.
I can't believe I didn't think of that one. I have seen two of those fail on other cars in recent years.
7. Motor / transmission mounts
The mounts actually look pretty fresh on the donor engine. I'll have to take a look and see if the transmission mounts are different between the two. I expect they are.
The coolant tank definitely sounds like a good idea.
