Old 10-08-2014, 01:00 PM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
you can also use a cigarette lighter plug to connect to the electrical system.
Charging through the cig lighter is a good idea, but it can be a bad idea to try to jump start the car from there. I have bought two used cars that actually had the insulation melted on the lighter wiring and shorting across to other wires from having too much current applied.
Also, I got the hood to unlatch on a water damaged '01 by applying 12v from a battery to pin 33 on the blue connector on the immobilizer box (probably the most complicated way to unlatch the frunk).
***Just noticed that you are in Scotland*** Are the manual release cables on the opposite side from the Left hand drive cars? Did you check both sides?
Good luck and careful with that axe.
