Old 09-30-2014, 05:13 PM   #1
JFP in PA
Originally Posted by jaykay View Post
With the ECU under control of the Durametric software, what is the effect (if any) of activating the cam shafts(...I believe it is called cam shaft change in the software)? At idle the cam shafts will already be activated...and the solenoid won't de-energize until 2500 to 3000 rpm IRC.
Will it just reverse the position? I wanted to try this to see if it would settle my cam shaft deviation numbers or promote a change when returned to the initial position and compared to previous data
The answer depends upon the year of the car (VarioCam Vs., VarioCam +). When the Durametric activates the solenoid on a VarioCam car, the cam will move around 25 degrees. On a plus car, it is more complicated as the cam movement is variable rather than a single step, plus the later cars with lift control will also be engaged, but you should still see positive movement in the cam angles as well.
The Durametric activation system is for testing components to simply make sure they work (on-off), not to produce a specific measured cam angle change. On the VarioCam car it is predictable because the system simply moves the cam in one step rather than the more variable plus system. In any case, I do not believe that test the VarioCam will solve your issue.
