Old 05-21-2014, 08:56 AM   #10
batshapedheart
batshapedheart's Avatar
do you have the low temp thermostat? And I assume being in Mijami you run the AC pretty much from the moment you put the key in the ignition? How many miles on the water pump and did you update to the latest coolant cap?
I'm the fourth owner so I don't know if I have the low temp thermostat, but I assume no.
I also know the water pump has been replaced at some point but the car came with no paperwork. I had a mechanic look at it and he said it was fine.
I don't think I have the latest coolant cap, but I'll try to find out.
And yeah, most of the time the AC is on.
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
