Old 03-25-2014, 04:25 AM   #19
stephen wilson
Originally Posted by LAP1DOUG View Post
Brad:
What kind of camber are you guys running square?
I used to run square until I put in GT3 arms and cranked in about -3 deg. in front, at which point I had major oversteer. Ended up going 255 Front / 285 rear which calmed down the oversteer.
I guess I could have cranked in some more front bar, but that seems to fall under the heading of "unsticking the end that is working", which Caroll Smith taught us not to do.
Thanks for any info.
The key is, don't use tire size to adjust balance unless there's no other option. Tires dictate the maximum potential grip, adjust geometry/alignment to get the tires working their best. The balance is (generally) adjusted with springs and bars. So to reduce the oversteer the easiest would be to stiffen your front bar, or you could install softer rear springs. Of course, if you don't have rules limiting you to 255's , stay with the 285's, and fine tune the balance in the same manner.
Caroll smith's quote doesn't really apply, you're not really taking away grip, you're just adjusting how much weight each end of the car has to "carry" via roll stiffness distribution.
