Old 03-19-2014, 08:10 AM   #2
Allen K. Littlefield
Allen K. Littlefield's Avatar
Originally Posted by Ranfurly66 View Post
Re the engine mount - thanks will get them to have a look, due for an annual service in November.
Thanks for the pointer. If the engine mount is past it then it'll feel even better!!! Though at at a cost, it is a Porsche.
__________________________________________________ __________________
Watched your video. Do I detect a bit of exhaust escaping on the left side of your diffuser or is the wind blowing in that direction? When you stop the area clears up. Check it out and see if I am just seeing things. You may have an exhaust leak over on the left as you look at the car from the rear. However I did not see any exhaust gas swirling around your camera which was mounted on the same side as I thought I saw exhaust gas. Just sayin, check it out and let me know.
AKL
