Old 02-16-2014, 08:39 AM   #11
Allen K. Littlefield
Allen K. Littlefield's Avatar
Originally Posted by Jamesp View Post
About 1% for dual row and 8% for single row. How much risk do you run not changing a timing belt? Some of those go a long time, some don't.
I have an '02 base 2.7 with single bearing, the most likely to fail (8%). Every oil change I check the magnetic plug and cut open the paper filter and check for ferrous particles. So far so good but the first evidence of iron in the oil on goes the new ceramic double bearing.!!! I am putting "resources", as the govt. likes to define money, aside for the operation.
I don't understand the semi or outright animosity toward Jake and his development of solutions to the problem. We all knew there was a problem with the number of posts concerning IMS failure. Jake came up with a solution and continues to refine the M96 for us. I thank him for that otherwise I would probably have just sold the car and moved on.
Yes, when I heard about the IMS failure I was "scared" but now have a fix. Porsche engineering unwillingness to admit to the problem or offer a fix scared me not Jake's solution. Let's keep things in perspective here after all we are all supposed to be friends.
AKL
