Old 02-15-2014, 04:08 PM   #1
JFP in PA
Originally Posted by Jamesp View Post
Done. Everything looked good. Tried to blow through the spagetti tubing and all the valves must be closed because there was no airflow. Is it common for the air injection cut off valve or the vacuum reservoir to leak? Could that be the source of the vacuum leak?
Definitely, the vacuum reservoir and its lines are common problems. If you have a hand vacuum pump, you can disconnect the reservoir and pump it down to test it.
