Old 01-29-2014, 10:34 AM   #11
Brad Roberts
Brad Roberts's Avatar
Most folks do not use rear adj LCA's
I use them on every car every time.. It settles down the toe gain under braking by replacing those worn out rubber bits on our donor cars
FYI:
Unless you perform tire temps.. on your car.. at the track.. camber settings are *only* guesses. I have drivers that heat their tires evenly with -3.6 on a shaved RA1, then I have guy's who heat the tires evenly with -3.2 on the same tire.
Camber is driver and track dependent. I don't run the same camber on the right rear at Willow Springs that I would run at CA. Speedway. The track design heats the tire differently. You see this in pressures also. You cannot run the same cold starting pressure in the left rear at WSIR as the right rear. You will burn down the left rear
All good info coming from group!! The toe gain explanation is one of the best I have seen online!!
Also: Raising the steering rack in the front to correct bump = we've been doing this for years in 914's and 911's. Porsche Motorsports does this on ALL the RSR's and I do it on Cayman's and Boxster's
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
