Old 01-17-2014, 08:19 AM   #2
alanqning
Take off the front right wheel, take off the wheel well cover and you will find the manual pull for the frunk. A bit of a pain. The plastic whell well cover has several plastic fasteners. They are two part fasteners. Pull out the outer pin with a trim removal fork tool. Take the pin out all the way, then the rest of the fastener will come out easily with the same trim tool. To reinstall, push in the fastener without the pin, then push the pin in to lock. Oil or use silicone to lubricate the plastic fastener so you can get it out easily the next time.
Don't pull the wrong thing! haha
Black on Black 2001 Boxster Base
Clutch Masters Stage III Clutch
Luk Flywheel // IMS Retrofit // Rear Main Seal
alanqning is offline   Reply With Quote
