Thread: Loctite 5900
Old 01-16-2014, 11:50 AM   #5
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by Bigsmoothlee View Post
And please dont lay that silicone on too thick, just a bead maybe 1.5mm thick is plenty. Remember that the excess ends up in the oil pump feed strainer....
As for regular stuff? I use Permatex's "the right stuff"
For flanges... 1.5mm is already too thick. Paint it on and thin as you can. As long as there is no break in the sealant bead you are good to go. In a perfect world sealant is not nec. but its not perfect so we have to have something to fill the voids.
I rarely use sealant on items with gaskets, but I do put a tiny bit in the corners.
