Old 11-22-2013, 03:02 PM   #11
JFP in PA
Originally Posted by Trax View Post
Yeah i'm looking on amazon and a few questions pop up all the time.
1. Can we use the cig Lighter as a charger without the key in the ignition.
2. I'm struggling to find a alternative to the solar solution. A battery pack that the car can draw from. I keep reading discriptions on amazon, but none of them say you can use it like that. They all look like you need the wall socket to draw from. Basically all I want is to charge a battery pack in the apartment via wall socket then when it's charged you bring it down to the car and charge it from the battery pack.
3. 2010 boxsters I believe use a Wet battery.. So, i have no clue what charger would be okay for that. A lot i see are just lead/acid based.
#1: Yes.
#2:Forget finding an alternative to solar, you are slowly turning this into physics experiment for no apparent reason.
#3: Correct, you have a flooded cell lead acid battery, so just about any maintainer would do the job.
Here is one I found in about 10 seconds on Amazon.com for about $20:
