Old 11-19-2013, 09:44 AM   #1
JFP in PA
Originally Posted by ganseg View Post
I bought one but didn't buy the lighter plugin. Will the wire to the battery clips close nicely under the hood if I just go direct to the battery? I assume I would use the winter setting.
You can connect it directly to the battery, but it is much easier using the cig lighter plug adaptor. What you call the "winter setting" (LED is marked with a snowflake) is for the AGM style battery (Optima and the like that require a special charge profile), what you want is the LED with the image of a car (conventional flooded cell batteries).
