Old 11-01-2013, 08:17 AM   #2
sb01box
it's most likely the case of bad switch in the recess where the top latches to the windshield frame.
with the top fully UP or down, if the waring light for the top (right most warning lamp) goes out, then the culprit is a small switch in the molding where the top hook grabs.
with the top all the way up, see if you can poke at the switch. if it is matter of it being recessed too far and the switch is functional, then the windows should roll all the way up. else most likely the switch needs replacing.
good luck
sb01box is offline   Reply With Quote
