Thanks, Kevin.
I did change the ignition switch and that did seem to alleviate a few problems.
I also have replaced the alternator and the seller's attorney replaced the battery.
I ordered a brake light switch to correct the brake light problem but the switch I bought was bad so I cleaned the corrosion off of the original switch and have that working again.
I have also replaced about 5 fuses (2 for the radio, 1 for the right rear light a 7.5 amp - the light I mentioned have problems with before - it is formally known on the fuse panel as "side marker right")
