Old 09-27-2013, 04:00 PM   #1
JFP in PA
Originally Posted by Last930 View Post
I recently had the AOS replaced on my '04 Boxster S; once that was done the RMS started leaking. Today I saw oil fumes coming out from the oil filler cap with the engine idling and fully warmed up. I opened the cap and there appeared to be a fair amount of pressure in the crankcase. What could cause this? The engine has 95k miles and runs great. I don't think it is a ring issue because it runs so well and has had consistent oil changes.
Is there something that could be missed or reversed during the AOS replacement that could cause this?
You bet, the AOS is the only source of crankcase vacuum, normally about 5 inches of water in level. I would revisit the AOS install before larger problems start.
