Old 09-16-2013, 11:13 AM   #10
dghii
You mentioned seeing condensation in the trunk when you checked your oil level (when engine is warm). Do you still see any condensation above the coolant and oil fill caps?
I had this happen on my 2000S...I'd loose just a bit of coolant over the course of a week or so. Coolant tank just two years old and cap ending in .04. I finally took a look at the O-rings in the pressure relief valve and found the larger O-ring to be pinched in one spot. I found a replacement O-ring at a local hardware store, installed it and haven't had a problem (or condensation) since.
