Old 07-27-2013, 09:24 PM   #2
owl1979
Thanks for your thoughts on this, Brad.
Won't the rub on the rotor lip cause either uneven wear (angled) or squeal?
Originally Posted by Brad Roberts View Post
Happens all the time.. run it!! Typically the pad is too SMALL and we end up with a lip on the outer edge of the rotor. This will not happen with these pads!!
Secret: I run rear pads on the front of the 2.5 and 2.7 cars ALL the time.
The difference is only 4-5mm of pad material. Gives me a little more rear brake bias
owl1979 is offline   Reply With Quote
