Old 07-25-2013, 10:25 AM   #10
JFP in PA
Originally Posted by runjmc2 View Post
I expect to looking at a 2005-2006 997 in the next few years and want to be sure I get the updated IMSB design. For the 2005 mid-year design upgrade, is that a M96 or M97? Asked another way, was the IMSB design upgrade only applied to the M97, or first in the M96 for a short period of time in 2005?
If the upgrade was in the M96 in 2005, that would obviously make it more difficult to determine which 2005's had the upgrade. In that case, can the VINs in the class action suit be trusted in this regard (e.g. if the VIN is not on the list, it is the upgraded IMSB design)
Thanks and sorry for taking a bit off topic
The "final solution" IMS began to appear in model year 2005. Unfortunately, the only way to know that a 2005 engine has this unserviceable design bearing is to pull the trans and clutch out, and look at the IMS center bolt. If it is 22MM, it is the last design bearing. There is no other known way to find out.
And just as a "by-the-by" the last design IMS fails as well, so it is no assurance of not having a problem.
