Old 07-18-2013, 09:06 PM   #3
Spinnaker
Spinnaker's Avatar
Check for fuel pump operation. Take off the gas cap and listen at the filler neck while someone turns the key to the "ON" position. Do not turn it to the start position. You should hear a whirring noise coming from the fuel tank. No sound means no fuel. Check the fuel pump relay and fuse if no whirring is heard.
