Old 06-10-2013, 03:41 PM   #1
black_box
DIY extremist
black_box's Avatar
Nope, not that simple.... I looked into this myself for my 2000s model. The 3.6 L motors have Variocam II, which requires a DME version 7.8 or higher. Our cars have a 5.2 DME. In order to swap the DMEs, you also have to swap the key transponder (you may be able to reprogram this), the HVAC controller, the ABS controller, and redo the back brake line routing for 4 channel ABS.
You will also need to redo the fuel pump and lines, along with the intake and motor mounts.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
