Old 03-17-2013, 09:57 AM   #2
JFP in PA
Originally Posted by alphaboy1 View Post
I was told that I can pull the Cam Cover bolts out one at a time then either replace or clean exisiting bolts with alcohal then a little permatex on the head and put back in in and make sure I do not over tighten. What do you all think?
That sometimes works but only if the leaks are from the bolts, although I would not use Permatex.
