Originally Posted by Bmod986
Allen I had asked in a previous post about this and did a lot of research. I wanted to make the pedal ratio 1 to 1. For JFP what this booster does is eliminate the uneven ratio. So when the pedal is 20% down your only geting a 13% opening in the throttle as an example. Im not 100% sure what the ratio is but it is definitely not 1 to 1 for safety reasons. But this is a bit annoying when your going from a stop on a hill. I wanted to know if there was a remap to make this 1 to 1 permanent.
I have a couple of friends who used cobbs tunners to remap their Japanese cars. I wanted to know if there was a product like cobbs but for my box. So far all the options are expensive.
In short the booster makes the pedal 1 to 1 ratio which makes the car "feel faster" and allows for a more precise engament with the car.
Bmod, do I understand correctly that you have installed one of these devices and are happy with it? Since my Boxcar is a TIP I think I have enough 'maps' that adjust to my driving style which may make this device redundant or irrelevant. It would be good to hear from a TIP owner with one of these. Thanks for your feedback.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
