Old 12-28-2012, 05:21 AM   #2
Bala
Originally Posted by Burg Boxster View Post
Having BTDT, unless you upgrade to a new amp w/ serious power... steer clear of 5.25" as their range is severely limited unless serious power behind them (40W isn't even close). You'll be extremely disappointed unless you pull out the stock "tuned ports" and make a baffle (links to DYI and template in archives here and on Boxster wiki) to fit 6.75 or 6x9" driver in there.
FYI - stock amp also has a crossover (no one that I've seen has been able to isolate the exact c/o point though). So, yes you want to go w/ either components or coaxial (and wire up only the woofer unless replacing stock amp).
Good luck
Most of time I'm listening to the songs off the ipod/iphone and it sound just fine (to me) even with the top down. Thanks for the input. I was confused on what I'd do with a coax as they come with the tweeter.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
