Old 12-09-2012, 09:30 PM   #1
drbodzin
San Diego Boxster
drbodzin's Avatar
Talking Painted Calipers
What a fun project. Took my time cleaning the calipers and painting them. Got the Porsche logo's off ebay.
Needed 1 can or DupiColor Red Caliper Spray Paint, 1 can of DupiColor Engine Clear Enamel paint, 2 cans of break cleaner, 2 wire brushes, one square of 400 grit sand paper, painter's tape, exacto knife. All together, under $40 bucks.
I chose to do the project without removing the calipers. I'm glad I did. No need to go into that much work unless you're building a show car. This is my daily driver.
Only thing I did was remove the brake pads.
Started by wire brushing the calipers. Then cleaned with brake clear and more wire brushing. You get the idea. Eventually got them squeaky clean.
I then used the 400 grit sand paper to sand all the surfaces of the calipers to ensure the paint has a good surface to bond too. I used the brake cleaner with a clean rag one more time. Don't rush the prep work.
Next I covered a third of the disc with painter's tape so no paint would get on them.
I used a plastic garbage bag to cover the rest of the parts by cutting a slit in the bag and stretching it over the caliper.
Next, I used the painter's tape to cover the bleeder valves, brake lines, the heads of the allen bolts that secure the brakes to the spindles, and the spindle metal where the calipers attach. I also taped inside the caliper to cover the pistons. The exacto knife comes in handy here, but is used more when removing the tape.
Now the paint. I applied thin coats of Red Dupi-Color Caliper Paint from every angle. It says to apply each coat within 10 minutes of one another. I applied a total of 6 red coats then let it dry an hour.
After the red paint dried, I applied the Porsche logo. Then 4 thin coats of the Dupi-Color high-temp clear enamel paint within 10 minutes of each other. I used a hair dryer to cure the paint.
I did this project 2 wheels at a time. The back two, then the front two.
Once the paint was dried, I removed all the tape. The exacto knife helps here.
drbodzin is offline   Reply With Quote
