Thread: Litronics
Old 11-26-2012, 10:04 AM   #1
JFP in PA
Originally Posted by thom4782 View Post
Brad:
As folks have said, the Litronics themselves are plug and play. I don't think the tilt feature is. My understanding is that a new module must be activated so the car recognizes it. If I am correct, you might need a code for the module from the seller so it can be programmed by a dealer or a independent shop. So check with a repair place first to see if the car can accept the module's commands.
The module to control the "swing up" high beam fill requires no activation or codes of any sort. You wire it up, it works...................
