Old 11-15-2012, 04:17 AM   #4
Heiko
Heiko's Avatar
Check your airfilter make sure it's clean and also check your throttle body and clean it out really good (you will likely have to take it off) but that only takes about 10min. Sometimes i've seen some dust buildup (from a badly seated air filter) on the MAF Sensor cause that too - use a little compressed air and blow it off. A little bit of dirt build up in the TB can cause all sorts of issues especially during low rpm...
Previously owned:
