Old 11-10-2012, 08:03 AM   #1
JFP in PA
The fronts are a direct bolt on with a base level Boxster, the rears will not fit without considerable work and expense because the base level cars used different rear carriers and e-brakes than the S model did. To get the rears to fit, you need to swap out the rear carrier assemblies and e-brake for the S style units, not a small or cheap project................
