Hello again seventythree,
It would be unusual for the flywheel surface not to be discolored! I have seen flywheels that have less than 3,000 miles on them with bluish-purple-amber streaks on them. I cleaned off my flywheel some ultra fine sandpaper and sprayed it down with brake parts cleaner. The discoloration does not come off, and is normal. Technically if it passes the twist test then it should be fine. I reused my flywheel when I did my clutch and had no problems.
