Old 09-19-2012, 11:40 AM   #1
Ghostrider 310
Ex Esso kid
Can you remove the key? I had to disassemble, lubricate and reassemble my ignition twice, apparently they gum up easily. Good news is the Bentley book explains how to take it apart and lubricate it. You may also find it helpful to turn the wheel each way when you try to remove the key as sometimes the locking mechanism can effect key removal. If it's out, try a high quality spray into the lock (break free CLC) coat the key put that in and work it that way as well.
