Old 05-24-2012, 02:06 PM   #18
JFP in PA
Originally Posted by stephen wilson View Post
I'm pretty sure all production engines bypass the filter on high pressure (when the oil is cold).
Some do, some do not. While the concept of an oil filtration by-pass seems like a good idea, a lot depends upon how it is done and how, when, and how dependably the by-pass operates. Approaches have been all over the map, some OEM’s put the by-pass in the filter mount (Porsche), other use a by-pass valve in the disposable filter itself. Others use none at all. Each has its own merits and drawbacks.
In a modern engine running a multi-weight full synthetic oil, there is really no need for a cold engine start by-pass, the oil viscosity change provides that function itself. Some would suggest that even then the by-pass would be a good thing if the filter clogged with debris from failing engine components as it would still allow some oil to circulate; but unfortunately by the time that would happen in a Porsche, the engine would already be toast and need to come apart anyway due to the damage done to the bearing surfaces by the circulating abrasive debris. And if there were a by-pass in this situation, the circulation of the contaminated oil would only worsen the situation; so at least if the oil pressure drops off due to a clogged filter, you would get a warning light and could shut the engine down before things got even worse.
Most by-pass valves are simple spring-loaded devices, which sometimes get stuck in the open position either temporarily or permanently (and why some use the “in the filter” style so it is regularly replaced with a new one). Unfortunately, you get no warning when this the by-pass fails, and dirty oil goes back to the bearings, and things get ugly.
We have had a lot of customers running without the by-pass for a lot of miles and over a wide variety of temperature conditions; to date none has suffered problems that could be tied to the lack of the by-pass, and during those miles every drop of oil was filtered at all times.
