Old 05-22-2012, 02:20 PM   #10
thstone
Brakes to slow, clutch/gears to go.
Use the clutch as little as possible and when you do, rev match. There's no point in downshifting sequentially, a 5-2 h/t downshift is the perfect answer.
Feel free to shift to neutral from any gear and coast/come to a stop using only the brakes. Saves wear and tear on the clutch and transmission. And if you're worried about losing power steering/power brakes, fix your engine because it shouldn't just cut out randomly.
